SBF accessory drive: Pulleys & Brackets, advice and pics needed
gunit
Apr 26, 2005
301
59
Mesa, AZ
www.gun-it.com
I am getting ready to put together the accessory drive on my race motor and am looking for advice, pics and a source for the best set up. The motor is a 650 hp SBF with Yates heads and dry sump.
The accessory drive assembly will need to drive the dry sump pump, two alternators, power steering pump and water pump. Is there a guru that I should talk to?
Sparky
Apr 4, 2006
704
39
Feeniks, Aridzona
Dry sump pump should have its own dedicated drive belt, typically a cog style.
You looking for v-belts or serpentine?
gunit
Apr 26, 2005
301
59
Mesa, AZ
www.gun-it.com
I understand that the dry sump should run on it's own belt. But I want to buy everything at once from one supplier, so that it all works together perfectly.
At this point, I am soliciting expert advice and I am willing to go with either v belts or serentine belt.
philofab
Powered by Optima
Jun 13, 2006
1,921
407
JRod's livingroom.
Talk to MotoXScott at Camburg... I believe he has a similar setup for his Bronco.
SROWE
May 2, 2009
113
HEMET CA
I have a complete serpentine set up for that motor and head setup give me a call if interested 951 926 8051 stephen
motoxscott
Feb 5, 2002
1,240
299
Huntington Beach, CA (SoCal)
This is where I got the crank pulley, water pump pulley and power steering pump setup. They didn't have a alt bracket that would work with the normal size alt so I modified a Powermaster version. They make great parts.
http://www.krcpower.com/
