Score starting order.
y2kbaja
2,908
1,391
I found this on the Score website. Sounds like qualifying is gone.
2017 SCORE In-Class Starting Order
For Remainder of 2017
Affected Classes: All classes not scheduled to qualify for specific event.
Qualifying Classes: To be determined by individual event.
2017 Races:
• San Felipe 250 / Event - Effective 2018
• Baja 500 / Major Event - Effective 2018
• Tijuana SCORE Desert Challenge / /Event
• Baja 1000 / Major Event
Summary: Finishing order from the below Events will set the starting order for the corresponding following Major Events:
• San Felipe 250 finishing order sets starting order for Baja 500.
• Tijuana SCORE Desert Challenge finishing order sets starting order for Baja 1000.
• Both the San Felipe and Tijuana SCORE Desert Challenge starting order will be set by the customary SCORE starting order draw.
The Driver of Record/Rider of Record (DOR/ROR) that finishes first in class in the San Felipe or Tijuana Event will start first in their respective class at the following Major Event, and the DOR/ROR that finishes second in class in the San Felipe or Tijuana Event will start second in their respective class at the following Major Event, and so on. If a team uses more than one driver or rider in the San Felipe or Tijuana Event, the DOR/ROR will be the one that qualifies by finishing order for the starting position in the next Major Event.
NOTE: Drawing for class start positions for next Major Event will be held in two (2) stages.
Stage 1- Drawing for DNF entries from previous SCORE event. Only exception is SCORE Desert Challenge events that assign points to DNF entries. Start position will be based on finish position for this event. In case of a tie for a start position, a draw will determine start position. Stage 2 - All DOR/ROR in
Stage 2 drawing will start behind the DOR/ROR in Stage 1. The DOR/ROR receiving the lowest starting number in Stage 2 drawing will start behind the last DOR/ROR in the Stage 1. The balance of DOR/ROR in the Stage 2 draw will be placed in the normal and customary SCORE starting order according to their draw number for the Stage 2 group.
Chris Tobin
5,998
1,177
2017 Races:
It says right there that it only effects classes that are not scheduled to qualify... so the classes that qualify, will still qualify!!!
y2kbaja
2,908
1,391
whoops. I guess qualifying isn't gone but starting order for other classes is affected.
