shock mount question
jo maoma
Heisenberg
1,612
351
i'm building a stock fullsize and had a question about running a second shock
up front.rule book says shock placement is open so i was wondering if i could
mount a smooth body through the top of the spring bucket like the dodge guys...
...thought i would see if i'm way off base before going to savage and jumping
thru those hoops. thanks in advance.
philofab
Powered by Optima
1,921
407
What is that thing?
How long does the shock inside the coil need to be? That coil moves around and I'm sure your axle/whatever travels in a slight arc... if the body sits to high above the coil bucket you will have clearance issues.
jo maoma
Heisenberg
1,612
351
What is that thing?
it's a land cruiser. looking to get a 11" smooth body that's 18.15" so
about 9" out of the top of the bucket. the front control arms are 30"
so the shock movement/angle change seems manageable....
...here is a pic of the build so far, my soccer mom racer.
philofab
Powered by Optima
1,921
407
You will probably have issues with a 2.5 shock when one side of the axle is fully compressed and the other droops... but you might be able to fit a 2.0.
Are you experiencing shock fade with that bypass?
DSRacing
Mini Metal MOD
3,455
358
If the rules allow for open placement of the shocks, I don't see why you wouldn't be able to. I've seen numerous 7s trucks using up to 3" dia. shocks with the same set-up on both I-beam and A-arm suspensions. Some have the shock body passing completely through the spring mount, others only the shaft. I prefer the latter, less material to remove from the center of the mount and less chance of the spring rubbing against the shock body.
jo maoma
Heisenberg
1,612
351
the bypass have never been run and that shock mount is from this trucks
previous life as a trail rig. it will get new shock mounts when the front is
caged. where i'm at now is i know i can fit the 2.5" not sure about anything
larger so i was thinking about running two shocks per corner up front. if
this is legal it may be the easiest if it's going to raise red flags i'll sell the
2.5"s (ouch) and try to figure out how to shoe horn a 3" in there....
Zambo
4,440
2,316
What is your actual question? Are you asking whether you can cut a hole in the top of that spring bucket so the shaft can pass thru? If so, I'd bet you could ask ten people and five would say yes and five would say no. The real truth is that nobody cares what you do with that POS land cruiser because you are going to get stomped regardless.
hahahahaha:D:D
jo maoma
Heisenberg
1,612
351
hahahahaha:D:D
don't sugar-coat it man, tell me what you really think.....
...just make sure i don't ever get in front of you i'll toss my
kid's car seat or a caffé latté out the window at you. :mad:
Zambo
4,440
2,316
Are you going to carry the spare Pampers in a bitchin' Thule rack on top?
jo maoma
Heisenberg
1,612
351
that's one of the dumbest things i've ever heard...
..i'm working on a sponsorship deal with huggies!
Haycock
412
18
why run the shock through the spring? why not just mount it in front or back of the spring?
jo maoma
Heisenberg
1,612
351
space. i'm just trying to add more shock. i've got as big a bypass behind
the spring as i can fit, and between the panhard mounts and steering box
and linkage there is no room in front. if its a bad idea i'll play around
with tires and wheel offsets to try and get more shock behind the spring
the main reason for the thread was to see if this idea was the kind of
grey area in the rules that i might want to steer clear of...
96YodaT1
43
my friend races kurt leducs old 7s ranger and since you cant have coil overs he put the shock through the coil like you said. the coil is a custom weight deaver i beam f150 spring and the shock is a 16" 3.0 king
