Shock Rebuild Help - Bearing Cap spinning even with 300 lbs of pressure
TauMau
Jun 27, 2007
997
32
Roaming
www.wisdomracing.com
So I had to do an emergency rebuild on the 2.5 Foxs for the class 9 before the race this last weekend. I loosened the allen for the bearing cap and started spinning...didn't loosen. I added about 50 lbs of pressure and tried again, no go. I added 200 lbs kept spinning and wasn't loosening. I got the pressure about to about 270-300 range and the damn thing still wouldn't loosen!
I ended up just doing a reservoir rebuild as that's all it really needed and decided to worry about it later. Now that 'later' has come, what do you guys think? How can I remove this bearing cap?? I thought maybe add some heat but didn't want to melt the seals and still not be able to get it off with only a couple days before the race but I guess now since it's no longer an emergency I can try it. What do you guys suggest??
cosmo
Super Moderator
Apr 1, 2003
1,920
181
Encinitas
Clamp the shock body (at the cap) in a vise with soft jaws. Don't crush it, just tight, you should be able to loosen the dust cap.
