small 40 spline spool with a 4" Carrier bearing?
lvzfyr
77
26
Hi guys,
I'm trying to make a bunch of parts I have laying around work and I need some help. What I have is a 3rd member case that is already machined to use a 10" gear and uses a 4" OD carrrier bearing. I want to put a spool in it to use the small 40 spline axles (Not the big TT 40 spline). Does anyone make a 4"OD bearing that will match up with a small 40 spline Spool? I'm trying to avoid buying a new case with a 3.25 OD bearing which is what all the spools I have found useand have to machine it to use the 10" gear I already have. Thanks in advance
PDANK Racing
737
193
Try an industrial bearing supplier like www.kamandirect.com. They should have a store in your area, and will be able to find what you are looking for.
Pete
