Solid body/cab mounts
redline
982
545
you need to measure the hieght and diameter of your sock body mounts while they are tight under your truck. Then go to a local machine shop and give them the size you want with a 7/16" bolt hole in the middle made out of 60 series aluminum. That is ussually the cheapest way to do them unluss you know someone with a lathe that has a big enough head. When i had some made for our F150 SuperCrew it cost $90.
