specs for ranger cross over steering swingers
kdm73091
Aug 27, 2008
169
west hills
does anyone have specs to build ranger cross over steering swingers? i have 6inch over beams. if anyone has dimensions and angles for them let me know please. i am trying to go for the giant motorsports ones.
atomicjoe23
Feb 2, 2008
4,058
72
Silverdale, WA
Do a search and look at all the pic's that are posted. . .it shouldn't be too hard if you are decent at fab work.
I'm going to be doing this as well on a Ranger TTB set-up that I'm swapping under a YJ Wrangler, but I have to finish our '49 Jeep Willy's project before I get started on swapping the TTB under the YJ, otherwise I would tell you what I end up with, but my beams won't be 6 over, only 4.
Jerry Zaiden
Mar 22, 2001
9,883
1,316
www.camburgEngineering.com
just because your beams are 6" over does not mean there is a standard swinger. You will need to work with where the beam and radius arms pivot and where the steering arm is located on the spindle.
I beams are very difficult to make work correctly..... A good design takes lots and lots of time. Good luck!
atomicjoe23
Feb 2, 2008
4,058
72
Silverdale, WA
As Jerry stated, most of these set-ups are built to the truck and are not standardized. . .a lot of work and trial and error go into them and there is quite a bit of fabrication required, but that's not to say that you wouldn't be able to figure out the steering set-up on your own.
Like I said. . .start looking at all the pic's you can of the different steering set-ups the well set-up Rangers have. If you can weld and cut metal proficiently, along with some fabrication experience you should be able to fabricate a steering system for your beams.
kdm73091
Aug 27, 2008
169
west hills
haha yea ive noticed that beams are prety tricky, thanks tho
kdm73091
Aug 27, 2008
169
west hills
yea i can proficiently fab up things lol, but its just my beams seem a litlle tricky haha
