Steel fuel lines vs braided
johndjmix
Mar 18, 2015
1,138
1,059
Denver, CO
What's the consensus on this. I'm thinking the only advantage to braided is ease of routing.
Why not use steel lines and bend them up/flare them? Vibration damage issues?
--John
Trophylite #6013
Dunarri LLC
wildscooterparts.com
coolermods.com
51rcr
Oct 28, 2013
867
529
box elder sd
I would say just cause braid is faster, maybe size also but that's more of an alcohol system
Shannon
Bear on a Unicycle
Jan 27, 2009
2,267
496
Campo,Ca
The only issue with steel lines are your transitions to hose.. make sure if you run steel lines that they can't wiggle loose.. it would be the first car to burn to the ground.
