Steering Problems
RC RACING
191
6
I'M HAVING STEERING PROBLEMS WITH MY 04 CHEVY AVALANCHE
I NEED TO REPLACE THE IDLER,PITMAN & TIE ROD ENDS. :mad:
ANYONE THERE WITH THE SAME ISSUE ???
I TALKED TO RCD THEY RECCOMENDED COGNITO KIT SEEMS TO WORK PRETTY GOOD
ANYONE USE THIS GUYS BEFORE? ARE THEY GOOD,RELIABLE ?
THANK YOU IN ADVANCE
steveG
1,961
87
WHY ARE YOU YELLING?
GM trucks in general have issues with the steering systems. They are weak and use inferior parts from the factory. We regularly replace ALL of the steering parts on 2 and 4wd GM front ends. Typically the ball joints are and upper control arm bushings are worn as well.
If you're buying stock replacement parts use ONLY Spicer/DANA/NAPA Premium chassis parts. They are by far the best.
alloutindustries.com
contact nick at nor cal truck in livermore california he does all the cognito steering upgrades there.. tell him pete sent you from all out industries he will probably hook you up..cool?
bottlefed98
17
Ive done a ton of the cognito idler pittman arm support kits and they work!!! by far the best addition to your stock steering you can buy
