Stolen 4 seat Jimmy’s buggy 3/1/22 johnson valley
whiteworks
Sep 18, 2006
21
23
upland california
Stolen 4 seat Jimmy’s buggy 5:00 am 3/1/22 from johnson valley, last seen headed north on Swanee from 247.
whiteworks
Sep 18, 2006
21
23
upland california
Please keep an eye out for these rigs, both were stolen from a locked garage in johnson valley on 3/1/22. We believe the vehicles to be in the lurcerne valley area of camp rock road, the 4 seat jimmy’s buggy was taken first, then the thieves returned for the LJ. Contact San Bernardino County Sheriffs Department with any information. As well please post these photos on as many places as possible.
whiteworks
Sep 18, 2006
21
23
upland california
SPECS: for buggy (parts list)
Motor: lq4 with GM hot cam and fitech intake manifold. Ran by Holley hp ecm and wired with Holley engine harness. Also has Holley 6" lcd dash for all temps and engine parameters.
Transmission: built turbo 400 with reverse manual valve body and art car reverse rock crawler shift pattern shifter
Tcase: atlas 2 with 32 spline outputs and 1350 non cv yokes 4.3 ratio.
Front axle: Dana 60 with 5:38 Yukon gears and spool. Spidertrax 300m axles shafts and Yukon super joints. Solid diff cover. Solid keyed knuckles with NWF keyed high steer arms. Spidertrax 14" rotors with wilwood 6 piston calipers. Yukon drive flanges.
Rear axle: GM 14 bolt with Yukon 5:38 gears and spool. Mark Williams 300m 40 spline full float shafts. Solid diff cover. Spidertrax 14" rotors with wilwood 6 piston calipers.
Suspension: king 14" front with compression adjusters 16" rear with compression adjusters. Double triangulated 4 link front and rear with all aluminum links 2" uppers with 1 1/4 Heims and 1 3/4 lowers with 7/8" heims. Billet weld washers on all link mounts.
Steering: all PSC hydraulic steering components with aluminum steering arms.
Drivelines: .188 wall with 1350 non cvs
Seats: PRP with seat heaters and camelbacks
Winch: warn 8000#
Tires: 42" reds
Wheels: 20" Kmc grenades
whiteworks
Sep 18, 2006
21
23
upland california
Please post and share, owner is offering $10,000 reward for information leading to recovery of these rigs.
Tube ride
Mar 12, 2016
2,185
4,029
Las vegas
I was out driving looking all thru wonder valley and 29 palms yesterday looking into a bunch of tweaked properties. A lot of people are looking for your stuff so keep us posted on ant developments.
