atomicjoe23
- 4,058
- 72
What year/make/model would you guys recommend for a 4WD IFS donor vehicle??? I would prefer A-arms, but I wanted pass on the TTB. . .going with TTB would probably result in a cheaper donor vehicle since I could go all the way back to 1980 for a Ford; I think I would have to go '97+ for A-arms in a Ford and I think '88+ for a GM.
I have an older truck that I would like to drop the body onto a newer chassis. . .I don't care what the make/model is, but being 4WD I know the mid/long-travel options are more limited than 2WD.
I would prefer an LS engine, but that's an easy swap if say the 4WD Fords have much better suspension options than the 4WD GMs; and an easy swap for an older GM as well.
The stock wheelbase on the truck I have is 118". . .that could be changed to accommodate a modern chassis, but I think that I will be looking for a single cab, extended cab at most. . .this will be a play truck.
Thanks for the recommendations
