Suspension design priorities? Scrub, camber change, track width change....?
jpndave
Jan 15, 2009
51
Hyde Park, UT
I am designing the suspension for my project and have a model built and close to ready, I think:confused:. What I have so far is; unequal length parallel (at starting height) A-arms, 16-18" of travel, 7 degrees of kingpin angle, 11" of separation between ball joints (using uniballs), lower arms about 28" upper arm about 17". I have the scrub (track width) near zero through the entire range of travel but camber change is not ideal. Bump steer is zero as is steering scrub. What are the most important aspects of these? I want to keep zero bump steer for sure, the other things I am not positive about. What about caster? All of this seems like a big compromise. Do I hold the scrub and bump steer at zero, deal with the lack of ideal camber change in chassis roll and just try and minimize body roll in the corners?
BTW, I have and have read, Tune to Win & Engineer to Win by Carroll Smith, Chassis Engineering by Adams, Competition Car Suspension by Staniforth, Race Car Chassis Design and Construction by Aird, Race Car Engineering and Mechanics by Valkenburgh. What other books and sources do you recommend? Is there an inexpensive independent design computer software program out there?
Thanks for any input here, I really appreciate it.
Dave
Scott_F
Dec 28, 2003
1,045
61
Tucson, was Anaheim
I would trade some side scrub and scrub radius for zero bump steer or a better camber curve any day. Your SAI seems too small. It IS a big compromise.
Scott_F
Dec 28, 2003
1,045
61
Tucson, was Anaheim
SAI = Steering Axis Inclination = A-arms
KPI = King Pin Inclination = I beams
Camber curve is personal preference. Most designs gain camber both in bump and droop, in the ~ range of 3-6*. Short course cars gain crazy camber like 10-15*.
atomicjoe23
Feb 2, 2008
4,058
72
Silverdale, WA
Most dezert trucks are running anywhere from 12-14* of KPI/SAI from what I have seen and been able to glean from the guys that have and build these things. . .
jpndave
Jan 15, 2009
51
Hyde Park, UT
Ok, so angle through upper and lower ball joints/uniballs at the outer(steering) side is SAI which is also what is referred to as King Pin Inclination on the early axles, right? What do you recommed that angle to be? I can set it wherever, no problem. My number was derived from Chassis engineering, Staniforth and Carroll Smith's books. As I understand that angle, less is better as long as you can get the steering scrub at zero (or minimized). Adams recommends 7-9 degrees (page 46). Staniforth states 7 degrees and "the less the better" (page 108). I couldn't find the reference to it in Smith's books. I am no expert on this and would really rather find out where I am wrong now rather than later. What should the SAI be? What advantages/disadvantages are there for the steeper angle?
I think that is about where I am at on my Camber gain, I'll look again tonight. It does start to gain rapidly at the extemes of travel.
Thanks again for your comments.
jpndave
Jan 15, 2009
51
Hyde Park, UT
Thanks for the comment Joe.
I think often they go to the steep angles to get the steering scrub to zero and still clear brakes, deal with wheel offsets, and one thing I have considered is the need to separate the two joints more for strength. The steeper angle allows them to get the upper joint outside and above the top of the wheel. That would be an advantage on a 15" wheeled car, especially the 2WD versions where the lower arm is really high on the hub for clearance. On those applications, there really wouldn't be a choice but to take the upper joint outside the wheel and go steeper on the angle to keep steering scrub down. The 4x4 (mine is in this catagory) have the lower arm below center to clear the cv and halfshaft which compromises clearance but gives the separation on the KPI/SAI. One of the major reasons I decided on 17" wheels was to try and keep things tucked up inside the wheel. Am I following all this correctly?
The steering would "self center" more with a steeper angle as it lifts the car when steered more. What other reasons are there for the steeper angle?
atomicjoe23
Feb 2, 2008
4,058
72
Silverdale, WA
I also started off with a KPI similar to what you are starting off with based on those books, but those books are biased toward road racing cars not off-road racing, something you have to keep in mind (by no means does this invalidate their usefulness. . .I used Heb Adams book extensively building the A-arms for our first buggy). . .
. . .with a larger KPI/SAI you also change the ratio of your UCA to LCA length. . .the shorter your UCA is compared to your LCA the more negative camber you will gain through a turn during body roll (and it appears that a lot, if not most, of the desert trucks have a LOT of body roll!!!) allowing you to have a better contact patch through the turn. . .
. . .suspension design is definitely a compromise. . .you have to decide what is most important for your application and then design it to suit your needs. . .I'm definitely not a pro at suspension design and am just trying to learn as much as I can and pass on what I have learned/been told to others as well. . .
jpndave
Jan 15, 2009
51
Hyde Park, UT
I feel the same way Joe. What KPI are you running now? I would really like to get things as close to ideal as I can the first time around. I can adjust the lengths of UCA to LCA to whatever works best. The KPI needs to be decided first or it will change everything else if adjusted later.
The theories all the books present seem to be valid. The problem comes in the extended travel and high cg heights that the off-road cars have. Trying to find a compromise that works almost seems an effort in futility. Minimizing weight and setting it as low and close to center as possible will work regardless. But, the height and long travel is unavoidable. Both of those are counter productive it seems on the handling. Minimal camber gain because of the long travel doesn't help in the handling dept. Long moment arm because of the high cg makes controlling roll difficult at best. I am looking at several ideas to control body roll without killing off road suspension travel. For now, I need a solid suspension geometry design. I will focus on the roll later.
I am going to try and minimize the body roll as much as I can. It makes sense that they have huge amounts of body roll as the "lever arm" between the roll center and cg would be quite large. They would need massive sway bars to controll all the roll. If the roll can be controlled, without killing the travel, things would be much easier to work out.
What do you think of a system like this?
http://www.fourwheeler.com/featuredvehicles/rpm/129_0207_july_2002_4x4_truck_auto_news/index.html
http://www.4wd1.com/didjano5.htm
http://aftermarketbusiness.search-a...spensio/ArticleStandard/Article/detail/504515
B Page
Feb 5, 2009
22
Gig Harbor, WA
What about setting your suspension geometry to place the roll-center closer to the CG, as a way to help minimize body roll in the corners.
How much negative efect would this cause to other handeling parameters?
atomicjoe23
Feb 2, 2008
4,058
72
Silverdale, WA
jpndave. . .I haven't had a chance to check the links out yet. . .I will when I get home tonight. . .
. . .as far as the KPI that we ended up on. . .well. . .we ended up not fabbing our own knuckles because we didn't have time to do so and be ready for the race so we used some OEM knuckles and we were stuck with what we got from the factory. . .I have no idea what it is because I didn't measure it, but it's nowhere near 12-14*. . .
Honestly if I were you I would stick with between 12-14* KPI just because that's what all the big name fabricators are running (to my knowledge. . .I'm sure there is an exception that I'm not aware of. . .), these guys are running these numbers because they work. . .so while you (and I) try to figure this stuff out for ourselves run what we know will work in the meantime and try to optimize the rest of the suspension system off of that foundation. . .that's what I'm gonna do as I build my budget play buggy. . .it will be my full-scale learning project.
jpndave
Jan 15, 2009
51
Hyde Park, UT
Raising the roll-center causes jacking and is generally bad as I recall from the reading I have done. The summary as I understand it is -1 to +3 as a roll center height, minimize cg height and control roll.
jpndave
Jan 15, 2009
51
Hyde Park, UT
What big name fabricators should I look at? I will be fabricating the knuckles so KPI can be whatever is best. I really don't see why you would want that steep an angle unless something else in the design causes that to be necessary. What separation do you have on those outer joints?
I need to decide for sure on the KPI and then sort out the Camber change. What kinds of #s are you looking for there? From my reading, they recommend matching the body roll. That may cause problems if the roll isn't controlled and could cause additional issues with the large amounts of travel we are talking about. The road race crowd are also dealing with very low profile tires where ours will be a lot more forgiving of less that perfect Camber and because of the high cg, we will never see the high g corners, at least not with the rubber side down.:D Somewhere on this forum I have read that the track width change was a big deal with the long travel suspensions. What I have designed now has near zero (like 1/4") change in track width over the entire range of travel and less than 3 degrees of camber change except at the very extremes where it goes to 4-5 degrees for the last 1/2-1" of travel. Zero bump steer and zero steering scrub.
djblakely
Feb 19, 2005
491
10
Saratoga Springs, UT
www.TeamXterraRacing.com
I just finished a set of uprights myself. I ended up at 13*. The factory ones were at 12*. I now understand why they are picking this number. It is to keep the wheel off of the upright post. For strength you want to have lower A-arm pivot as close to the hub face as posible. The closest I could build was 5 1/2". Then I went with a 4.5" back spaced wheel. I only have 3/8" between the inside lip of the rim and my upright. BTW- I set the caster at 12* and the wheel is at 4* negitive camber at droop, 0* at mid stroke and back to about 4* at full compression.
Dirtrunner21
May 8, 2009
24
Las Vegas NV
good info guys... quick question... do you guys use a certain program to do all the geometry? or is it by hand? I want to get all my numbers correct but im not sure which way to do it. any help would be awsome. thanks
djblakely
Feb 19, 2005
491
10
My brother is a strucual detailer by trade. We use his CAD program and laid out 3 drawings with all the details and measurements listed. It looked great, but we soon found out what most fabricator will agree with, it's not perfect. I ran in to items making contact through the range of motion. I had to go back and cut up some beautiful 4130 work and modify it for clearance and fit. It did give us a good baseline to start with. I knew how long each arm had to be, how much travel to expect and what camber/caster number would be.
Funny thing is I had already laid this out with poster board patterns on a sheet of plywood, with thumb tacks in the pivot centers and came up with most of the same info. Then my brother came by and says "why are doing that? I can do it all on CAD for you".
So there you either way works. Good luck on your project.
atomicjoe23
Feb 2, 2008
4,058
72
Silverdale, WA
I currently use AutoCAD for this stuff, but I just got SolidWorks and will be learning it so that I can avoid the problems that djblakely brought up with interferences. . .with SolidWorks I will be able to animate the assemblies and find out about clearance and interference issues ahead of time. . .
. . .the SolidWorks version I have now is only a student edition (full version, but only good for 24 months) so I will probably be switching over to Rhino3D once the license runs out becuase the Rhino student edition licensing never expires and is much more affordable to upgrade to the professional version than SoldiWorks ever dreamed of being!!!
Dirtrunner21
May 8, 2009
24
Las Vegas NV
hmm thanks for that.. ya i can get autoCAD student version and have one of my friends help me with it but much rather use plywood and cardboard for mock up and what not... it feels easier to me and more of a feel then just the cad program but thanks for that.. ill use cad still but ill also do mocking with wood and cardboard :D
mniemiec866
Jun 22, 2010
60
10
Charlotte, NC
For anyone looking to design their own suspension, I found this suspension analyzer online and its free for 10 days, and you can print your numbers off when your done. I'm in the process of redesigning the front suspension for the Rally Fighter at Local Motors and this software is very simple to use and gives great graphs and animations. I started with the Supra Twin Turbo option that is gives since is an A Arm front suspension and then started creating my geometry. I've then drawn up my geometry and design in solidworks and it acts the way the graphs and animations show. I've yet to start cutting metal and doing the fabrication, but it seems to be a really good building point for people to design a suspension and to understand what changing the variables on a geometry will do.
http://performancetrends.com/SuspAnzr.htm
