T-Handle Valve
OneTime12
44
I need to pick up a T-Handle schrader valve for my nitrogen kit. I spoke with Mckenzie's and they said they are back ordered. Im located in Downey and was hoping for someone closer than Kartek. Any help would be great. Thanks in advance.
Will
Justin
340
9
I've gotten a few from Borg Equipment & Supply, Inc for quite a bit cheaper than the off road shops.
Samco Fab
1,162
393
Try a Catipilar heavy equipment dealer, that is where I got mine from.
The part is a Schrader #2755
Has anybody ever found replacement copper seal rings for the inside of these things. I have one that I wanted to rebuild.
OneTime12
44
Thanks for all the help. I called Borg Supply and they were out of stock also, so I just went to Kartek and they had several instock. Thanks again for all your help.
nope. gotta machine them yourself. Thats the one thing that sucks when using them for production.
atomicjoe23
4,058
72
What is the size of the copper seal ring. . .if they are a fairly common size one of the online motorcycle retailers sells a large variety pack that contains most normally used size.. I haven't personally seen the rings that you are talking about, but I have had trouble tracking down the copper crush washers for hydraulic brake systems in the past and this is how I finally solved the problem.
cosmo
Super Moderator
1,918
180
Lots, maybe a few hundred? Never put a wrench on the rotating nut. You will destroy the washer,,fast.
