Tire Clearance
JrSyko
Jerry Maguire
Apr 8, 2001
7,890
1,611
I have a '98 F-150 4x4 with a RCD 6 inch lift and Nationals in the rear all on 35's. My problem is this: my rear tires rub the outer fender well just enough that something needs to be done. I don't want to put fiberglass on my truck (not a prerunner = disco) and I hate the look of flaired fender wells (again disco). Do I have any other options? Has anybody had the same problem and done something different? Furthermore, I get a little tire rub in the front. I thought that the RCD kit was designed for 35's? Does anybody else have the same problem? Thanks in advance and see ya in Laughlin!
JrSyko
Jerry Maguire
Apr 8, 2001
7,890
1,611
Before a war errupts, let me clarify. On a truck that is NOT a PRERUNNER (i.e. does not have huge amounts of travel and thus no need for fiberglass like mine) than fiberglass is DISCO! What function does it serve other than looks? I hope we can all agree on this point as there is a need for fiberglass on some trucks, just not on all trucks.
John Bitting
Administrator
Apr 10, 2001
11,951
2,561
Rancho Santa Margarita
race-dezert.com
I was just messing around. There will be no war.. I dont see many options. You have ruled out the easy ones by flaring and going glass. The only other option is going with a skinnier rim, smaller tire, or trimming the inside lip of the bed.. Or a huge block and stink bug that bad boy..:)
Tony_Barraza
Apr 1, 2001
2,021
103
San Jacinto, CA
www.facebook.com
Travis-
What's up Bud?
If you don't want to cut or pull the bedsides, you may want to rethink the width/offset of your wheels..
I'm sure you don't want to buy new wheels if you don't have to, but, I remember your truck from the pit at Ojos Negros at the Baja 1000, and it seemed pretty clean. Do you really want to start cutting and pulling at it?
Or, there is always John's suggestion of going Stink Bug Grande...
Happy New Year Bud!
Tony B.
jeff
Moderator
Apr 1, 2001
7,454
352
California
www.performancelifts.com
If you don't run fiberglass and you don't flare the bed... exactly what do you propose we suggest? I can think of plenty of smart ass remarks that won't help you a damn bit - here goes!
How about you cut the entire truck in half down the centerline, widen it by 1" inch, and weld it back together?
You could take the rearend to a qualified shop and tell them you need it 1" narrower to clear your tire.
You could take the tires to a shop with a grooving iron and they could cut your tires down to fit.
Get some of those plastic Bushwhacker fender flares, trim the fender to allow the tires to fit and hide the hacksaw cut with the flares.
Get new tires?
Get new wheels?
Allow the current rub to fix itself. (might require actual off-road use)
I think your street queen would like fine with a slight modification to the rear panels. If it only requires a gnats ass of clearance the flare will hardly be noticable.
Aloha
PS - I'm just kidding so don't take any of this too serious.
Mikey
Oct 4, 2001
139
Sunland, CA
Dude, looks like glass would be functional on your truck, so it wont be disco! You can just pull the
back half of the bed side ever so slightly to clear the tire. It probably will not be noticable.
TRDshaunTRD
Jul 7, 2001
1,061
Hawthorne, CA
www.sextonhomes.com
cut the inside of your wheel well. Then pull out your bed side enough for your tires to clear and either weld in brackets to keep the bed side out, or bolt some in. This will not look disco and won't even be that noticeable.
Greg
Apr 2, 2001
1,116
19
Riverside, CA
prerunners.com
Jeff, you forgot about installing a set of "dually" fenders.
Greg
Jimmy8
Apr 18, 2001
3,659
1,329
Parker, Arizona, USA
www.DownAndDirtyShow.com
You know what, I saw dually fenders on a F-150 one time. They put them on a truck with a really wide rear end and it had longer I beams up front with some fiberglass up there. Looked pretty trick really.
PMC Racing
Jun 18, 2001
298
Just scrap the bed and zip tie the brake lights to the frame rails....no worries of disco then, and you are guar-own-teed not to rub anymore.
"Revenge is best served cold"
jeff
Moderator
Apr 1, 2001
7,454
352
California
Damn Greg, you got good ideas too. :) Running a dually fender on a non-dually truck would be a totally non-disco idea. I completely missed the ball by leaving that out. I did however come up with another possibility... Instead of having someone cut the rearend down an inch --- why not just heat up the axle tubes red hot and jump the truck once to get a nice bend going... the bend would reduce the width and would allow the tires to clear.
Aloha
Jun 18, 2001
298
Go to a shop that install lowering kits and have them roll the fender lips. That should be good for about .75" and you can't even tell.
