tires?
fnkrngr
29
What size tires will fit on my ranger,it has glass front and rear,camburg coils,bent beams,ext. radius up front. I want to run 33x10.50 but it looks like they will rub in a turn at full compression, I know this is not a likely situation but i just dont want em' to rub
You dont know the looks i get with this truck on the east coast.
They will hit fire wall and upper fenderwell. The worst part is that it hits the main wire loom coming in on the pasenger side after a while. Your best bet if you want no rub is to get longer radius arms so they put the tire farther forward and get extended beams or wheelspacers if you are not too hard on it.
fnkrngr
29
What size will work with what i have on the truck now?
Mine rubbed with 31s! and I had pretty much the same set up. Another thing you could do is put a big bumpstop in there so it can't come up and hit the fender. 33s are the way to go if you have glass but rubbing is somehting that you jsut ahve to deal with.
singlehanded
1,584
ya got some hydralic stops on my truck and my 33 never hit anything ecept hiting my radius arms at full turn, going to 35 soon.
