Too much spring?
04yfzkid
Jul 26, 2007
107
7
Oceanside, Ca
I am trying to learn more about shocks and such. I have gotten the idea about valving and adjusting bypass tubes down somewhat, but I don't understand about spring. How do you determine if you need more spring or less spring in a truck.
In my truck right now when I hit small little bumps, I feel every bump in the front end. I have owned 5 lt trucks in the last two years and this the only one that has felt like this. For example speed bumps are pretty rough, and I feel every pot hole one the road. I am saying this because even on really hard dirt roads (like bessimer rd) it rattles my teeth out of my head. It feels good in the rougher stuff though up front. My thought on my truck is that it has too stiff of springs so therefore the valving plays very little roll on the small bumps.
My springs are not labeled anywhere as to what rate they are, and I am unsure of the valving. I have the coilover valving written down somewhere, but not the bypass.
Truck is a 93 extra cab ranger with a 4.0. Has 8" over a side Giant Motorsports beams, 14" coilover and bypass with a simple hoops / crossbrace, and a small rubber bump. It's running on 33's also.
Thanks for any help in advance guys,
-Mikey Smith
04yfzkid
Jul 26, 2007
107
7
Oceanside, Ca
I am horrible with guessing how much. Here is a picture lol.
Wild bill
Jun 23, 2008
713
30
ponca city, ok
Here's a total guess. I would go with a longer upper spring with a lower rate. Example....top spring is a 6"x250 now go with a 8"x200 or 150 .
Feb 19, 2002
6,708
1,535
Easton, KS
It's really imposable to tell from a pic like that. You would have to jack it up and unscrew one side to see how much pre-load you have.
Giant Geoff
Jun 18, 2008
725
91
Santa Ana, CA.
www.facebook.com
Mike, the coil over shock you have was set up to run by its self and has a 15/10 in it and would need to be lighten up to run with the by-pass how, plus you should switch the shocks and run the coil in back of the by-pass. If you do this I would suggest this for the shock valving. By-pass 15/10, coil 10/8.
04yfzkid
Jul 26, 2007
107
7
Oceanside, Ca
Thanks geoff I will go ahead and try that. I need to open up them all and rebuild them. Oil is pretty nasty in there haha. When you referred to the valving is that a 15 stack on the compression / 10 stack on the rebound, or do I have it backwards?
Giant Geoff
Jun 18, 2008
725
91
Santa Ana, CA.
www.facebook.com
Rodger.
For sure do up coil overs, there were on the old truck for a long time but those by-passes are new so just check the shims, leave the oil and seals.
04yfzkid
Jul 26, 2007
107
7
Oceanside, Ca
Rodger.
If I can get the shims, I may try all this before the race this weekend. If not oh well. Thanks for all the help geoff, I will stop by saturday / sunday sometime and say hi.
WannaB-class5
Feb 8, 2005
445
17
El Segundo, CA
Mikey, Get the shims! We can do them at the race if needed. Don't waste a trip to the dezert without dialing in your truck!
TOTTI
Jan 7, 2009
48
Mexicali, Baja
Hey maybe I can use some good advise from you guys..I have a Bronco its still a work in process..I have 14"coilovers for the front the springs are upper 14" 350 and the lowers are 16" 700, the ones in the back are also 14" coilovers with upper spring 14" 250 and lower 16" 600.. Do you think its a good setup?..
Thanks..
cosmo
Super Moderator
Apr 1, 2003
1,920
181
Encinitas
Thanks..
Sure.
Feb 19, 2002
6,708
1,535
Easton, KS
Thanks..
That's going to be really stiff! Trade the 700 fronts for some 400's. Trade the 600 rear lowers for some 400's.
Feb 19, 2002
6,708
1,535
Easton, KS
Yes. You will have to have the springs loose to get it to sit at anything resembling a normal ride height. You will not like the way it rides.
04yfzkid
Jul 26, 2007
107
7
Oceanside, Ca
Ok so this weekend I was screwing around in the desert. I haven't revavled my truck yet do to my shims still in shipping. So I decided to take off the bypasses and run it. Well it did a ton better this weekend. I know I still have a lot of work to do.
I did notice something that I thought was very odd. When I was hitting whoops, or even small washboard stuff, the truck would litterally float and move all over the place. Can anyone explain why that is? For example too much tire pressure, too much spring, too much compression, too much rebound, not enough of certain things?
Also got a little video. I need to add some compression to the rear. I was watching the video in slow mo (hitting the play and pause button over and over lol), and I noticed the when going over the whoops, the rear tires would come off the ground slightly. Is this normal or should they be sinking all the way down into them?
[ame="http://www.youtube.com/watch?v=gdm-HNgLmOE"]YouTube - Devil's Slide fun in Oco[/ame]
Sep 4, 2009
Mikey,
I know that I have seen several pics of your truck...
I cant remember though... Do you have cross over steering?
Watching your video, I noticed the bumpsteer slightly...
As for the rear suspension, what are your rears valved at?
