This may be long winded and of no help but:
To Quote the Summit catalog:
BUILDING THE PROPER ENGINE:
A torque converter reacts to engine torque: the more torque you feed a converter, the better it will perform. For a converter to operate properly, you need to build your engine to make as much low and midrange torque as possible in the same range the converter is rated for.
STALL SPEED:
Nothing about torque converters is more misunderstood than stall speed. Stall speed is directly related to the amount of torque your engine produces-the more torque, the higher stall speed. For example, a converter with a 2,800 to 3,200 rpm rating, might provide approximately 2,800 rpm of stall speed behind a small block V8, but about 5,000 rpm behind a big block making 800-plus ft-lbs. of torque. Without knowing how much torque your engine makes, you cannot know how much stall speed a converter is capable of.
That leads to perhaps the biggest problem people have when buying a converter: stall speed ratings. While most converter manufactures list stall speed ratings, those numbers are very, very general guidelines: true stall speed is impossible to measure due to vehicle variables. the time-honored method of testing a converter's stall speed--holding the brake and reving the engine while in gear--doesn't work, primarily because the tires will spin before you reach the converter's stall rpm.
Most complaints about converters center on a stall speed that is too low. The problem is usually a lack of low-end torque, but there are other variables that can contribute to lower stall speeds, including the following: Low vehicle weight...Small cubic inch engine...very low compression ratio...Tunnel ram-type intake manifold...Large carbuerator throttle bodies..Mechanical secondary carbuerator linkages..Multiple carburetion...Long duration camshafts...Retarted cam timing.
Heat is the biggest enemy of your converter and transmission. Stepping up to a higher stall converter can impose higher loads and create more heat, so proper cooling is essential
