Toyota 3.4 Conversion
Bajatoy
51
I am thinking about putting a 3.4 in my 92 4x4 but dont know how hard the conversion is. I looked around on the internet and cant find much or anyone who has done a conversion. I was told that it will bolt directly to my transmission but dont know for sure. Does any one know how hard it would be, what parts I need to change and what it would take to keep it smog leagal in AZ? Or even any pictures, I know there was a tan toyota and the jump championships 2 years ago that had 3.4 in it.
Thanks for any help!
YotaWhoopRunner
137
I'm not sure this will help, but here is a rock crawler that has done the conversion on his 86 4x4 which basically has the same drive train.
yotatech
184
Dan just put a 3.4l in his truck and i think fish is putting one in the piece as well.
SuperDave
260
Let me know what you find out. I want to do the same conversion on my '94. So far all I know is I talked to a guy that successfully did this on his '91 pick up. He found a Tacoma that was totalled and then transfered the engine and all the engine components and electrical to his truck. He said the motor mounts have a variety of mounting holes to bolt the mounts to the block and to the frame.
fishd00d
What A Joke
15,503
5,435
Heres the scoop.
The V6 3.0 transmission will bolt to the motor....but you need to find a flywheel off of a 3.4 I believe. We just put one in Dan's truck and it works great no problems so far!
Dan will come on here and tell ya all the specific parts you need I am sure.
Bajatoy
51
I am assuming that the 22re transmission is the same too? My 22 re timining chain guide broke and went betwen the sproket and chain. The chain slipped a couple of teeth and bent all the intake valve and three of the exhaust valves!!! OUCH!
WFODAN
1,937
126
Actually the swap isn't a walk in the park .
Fist off , the 22r transmission is way different . If you want to run a 2wd 5 spd then you need to get a R150 trans . It was the transmission that toyota put in their 89-95 V6 trucks . You need to get the flywheel out of the 3.4 ( which I found wasn't an easy thing to get ) and run the clutch for it , while running the throw out bearing for the R150 trans . The next problem is the oil pan and pick up tube . If you have a 2wd truck that you are putting the motor into then you need to run a 96 T100 2wd oil pan and pickup tube assembly . The next problem is that all the late model 3.4 motors are front sumps so the dipstick is also in the front . There is a blank in the drivers side of the block , under the motor mount that can be drilled out to run a rear dipstick . It was the spot for the dipstick tube for the early motors so toyota never took it out of the block on the newer ones . They just left it as a blank . The 3 row radiator can be run out of a 89 to 95 v6 truck also . It will fit right where your factory 4cyl radiator went . The factory hoses can be used also . As for the computer ....... I just hot wired mine to run . Since mine went in the race truck I didn't worry much about the guages and such on the dash end of the loom so we just focused on what it takes to make the motor run . We also built our own mounts so I'm not sure how you'll want to do it , but the 4cyl frame mounts are too far off to work . Way too far !! the transmission needed to be moved forward on mine to reach the motor and the firewall had to have lots of love given to it . Those are just a few of the things you'll need to know going into the swap . If you want to take a look at mine to see more PM me and I'll let you check it out .
After driving the truck and racing it for the last two weekends , I keep asking myself if it was really worth it , just to go slower . Hopefully the reliability factor comes in soon so I can see some positive about it . LOL!! Good luck .
WFODAN
1,937
126
I was thinking about putting the TRD supercharger on it , but was told it might be a bad thing . I've heard nothing but horror stories about them leaning out on the top end ........ I've heard that someone makes one that uses a different fuel system all together . I'm still looking into it .
Jordan
978
Dan,
If you are looking into 3.4L upgrades go to this site
http://www.gadgetonline.com/4Run.htm
Gadget's 4-runner probably has more on it than any other 3.4L I have seen. His site is very detailed on all engine work, performance mods, DYNO tests, etc..
Great info
Bonzen
322
Yeah good idea Jordan. Gadget is a freakin mad scientist!
-Ryan
Curtis Guise
Administrator
12,454
3,201
supposedly you aren't supposed to put the SC on a 3.4 earlier than a '97. I found that out after putting it on the '95 I am building. The main problem is with the ECU. But so far the cheapest way around it that I have seen is to get a Perfect Power SMT-6 unit for $300 and a better fuel pump than stock and you can adjust your fuel and timing system with a laptop with that SMT-6. There are also a couple of other things that help and may or may not be necessary just to get it to run right. Bigger injectors, different spark plugs and one or two other things. There is a huge thread on it at www.yotatech.com and some guys have been dialing in their trucks with the SMT-6. Here is a link to the thread. http://www.yotatech.com/showthread.php?s=929b3cf23b071ed7b16b3edad59fe396&postid=159033#post159033
the guy "ravencr" has used it on two trucks so far. he also started another thread about his second install.
You can also get a stand alone system for the engine and get rid of the stock ECU. I have also heard of people that put the SC on their '97 or later and it works great. So once I finish the front of my truck and get it rolling then I get to make it run right.
SpeedRacer
51
Is it official forced induction is legal at MDR? Last thing I heard from Art Savedra was that all race promoters including MDR do not allow forced induction in desert racing. I understand Jerry raced a forced induction motor in his Lucas truck but no one protested.
pphat
396
WFODAN
1,937
126
ya I looked at off road solutions when I started the swap . The biggest problem was the price of their stuff and they made nothing for the 4cyl to 3.4 conversion . It was all 3.0 to 3.4 .
As for the super charger being legal in MDR ....... It's only legal in the 1450 class . Since 1450 is called a "street legal class" then they do allow street legal super chargers . Jerry from Camburg is the one that got that ball rolling . He wanted to eliminate the windshield rule and allow super chargers . Art only went with the superchargers . So to answer the question , yes they are legal in 1450 .
My main concern was the leaning out of the motor under boost . If you could imagine getting in your street truck and putting it to the floor for about six hours , then you could almost simulate an off road race . Leaning out would be the result , and the exhaust temp would go threw the roof .
As for the manual transmission being tougher than the auto ..... Not really . I was almost going to make my truck an auto for a few days , but decided to go with the manual . I am currently running the ECU out of the donor truck I got the motor from, which was a 2000 4Runner Automatic 2wd . I have had no problems running the auto ECU with my manual trans . As for bolting up ........ There was no problems with that either . The R150 went right to it .
Bajatoy
51
Off road solutions site says that there is 4 cyl conversion kit in the process. I am going to contact them also and see what they say. Will keep you all posted.
Thanks for all the great help so far!
Keep it coming.
pphat
396
Sorry, missed the part where ya had a 4 banger... Like I said, not cheap for the whole kit... but not having to wire it myself, I'd pay for that.
Cool... I've read that some of the 3.4 engines that come out of trucks w/ automatic trannies have different crankshaft machining than the manuals. Don't know the exact years, but apparently those years wont accept a flywheel or pilot pbearing. My understanding is that the ECU only matters if you're running the auto... the manual can use any ECU.
Good luck w/ it!!!
Travisfab
708
219
Not to get off the topic, but has anyone heard about the supra 7mgte motor, it is supposed to be a fairly easy swap, I know that supra can pull some big numbers, seems like it would be a good motor for a desert truck
