Toyota/Tundra tracton control
Hi I am in need of some help. I have a 2008 tundra 4x4. I would like to completely disable the vsc permanently. I am not sure if it is the same in tundra as in tacoma. I have looked everywhere but no luck.
I have removed abs fuses but that also shuts off 4x4 and speedo. Any suggestions would be great. Thank you.
Dustinose
red square fuse in the box under the hood by battery.
It will turn off vsc, abs, and make your dash look like a xmas tree
Ive been running that way for years
I have taken that out. It also took out 4x4 and speedo and a few other things. So do not want to do that I need 4x4 some times. Thank for the suggestion. I heard bully dog programmers will turn it off also
Really do you know if it the abs 1 fuse or abs 2 fuse. I have 2 red fuses 1 is a 50amp the other is a 40 amp. Or at least I think they are red I am very color blind.
