trans. cooler location?
singlehanded
Jun 3, 2001
1,584
Placentia,Orange County
Where is the best place to put my trans cooler for best air flow in rear cage?
singlehanded
Jun 3, 2001
1,584
By the way it is 10"x10"x3/4" two stacks and a 10" fan behind the two stacks. total dimensions are 16"x10"x4 1/2"deep. should it face the side for best airflowor forward will it get any air from over the cab, should I mount it off the two middle cross bars, maybe fab something there? any ideas installing this weekend with my c4.thanks
singlehanded
Jun 3, 2001
1,584
come on somebodys gotta have an idea or thought of where best to place it for max air flow?
hoeker
Oct 9, 2002
2,004
101
holland, MI
www.rosshoek.com
shouldn't matter much if you have a good fan on it and good quality coolers. put it where it's protected from tire debris. a friend on mine has his facing back, about even with the bed side and 6" from the cab. works fine.
those c-4's are good trans, but have very litttle extra flid capacity to help with heat disapation. i would recomend a deep pan, and make sure you can keep it cool, before you go out and beat the heck out of it.
"to be successful, you must first learn to disagree without being disagreeable."
RacerX
May 21, 2001
1,094
61
Fontana,CA
you have to find out which way the air is flowing through your back area. Tape some streamers to differnt places in the rear, and drive down the road and see which way they are blowing. Thats the best way to find out where to place it.
singlehanded
Jun 3, 2001
1,584
My friend gonna give me a stock c-4 pan that is deeper, doesnt have a drain plug but for now thats alright
Jun 18, 2001
299
Tap a whole for a temp gage while you are at it.
hoeker
Oct 9, 2002
2,004
101
holland, MI
www.rosshoek.com
i usually use the temp sender hole for the drain. 1/2 the work
singlehanded
Jun 3, 2001
1,584
Was going to buy a deeper pan from summit tonight. My friend recommended a tci w/ filter extention its around a hundred bucks its what he has in his c-4. Anybody know if this will work fine for my application he has a dragster?
singlehanded
Jun 3, 2001
1,584
its got a drain plug and holds 1 more quart also has fins on bottom for better cooling. We were going to run the temp guage from the lines.
hoeker
Oct 9, 2002
2,004
101
holland, MI
www.rosshoek.com
that should work good. be careful installing it, some of the cast pans need a little clearancing by the shifter mechanism.
i like to run my temp gauge in the line too. true operating temp.
singlehanded
Jun 3, 2001
1,584
So one more ? whats the best way to run a sensor to a steel braided line? dash 8 by the way and where can I get a sensor from?
hoeker
Oct 9, 2002
2,004
101
holland, MI
www.rosshoek.com
i usually run a remote oil filter, they have an extra hole for a temp sender. keeps the fluid nice longer too.
need to change the filter regularly.
