transmission Specs On A 1988 Bronco
Status
Not open for further replies.
RC RACING
191
6
HERE'S THE DEAL I NEED A C6 transmission, A FRIEND WORKS ON A WRECKING YARD THERE'S A 1988 BRONCO I CAN GET THE transmission FOR PENNIES :eek: BUT I DON'T KNOW WHAT KIND OF transmission COMES WITH IT :confused: SO I GOT THE VIN # HE IS ALSO GIVING ME THE SERIAL NUMBERS FROM THE transmission PAN??? & MAYBE WITH THAT, ONE OF YOU WIZARDS CAN GIVE A HAND DECODING THAT THING :confused: I DON'T KNOW A THING ABOUT TRANSMISSIONS HELP PLEASE
IF IT'S A C6 I'LL BE GETTING EVERYTHING TRANSFER,transmission,DRIVELINE,ETC.:D :D
THANK YOU
steveG
1,961
87
Why are you yelling?
If it's a 3 speed then it's a C6.
RC RACING
191
6
nobody is yelling, and that's why i'm asking this because i don't know
if it's 3 speed or what, maybe you know something i don't.
I need a to be sure this is a c6 before I purchase this thing.
steveG
1,961
87
Instead of getting the VIN and serial numbers, can you have your friend check if it's a 3 speed? He can check the gear indicator for an overdrive symbol or if it happens to be gone, have him count the number of detents at the shifter or shift lever on the transmission.
If all that fails, a dealership parts department should be able to tell you what trans it has if you give them the VIN.
Status
