Tremec TKO 600 or other manual transmission in a Trophy Lite?
pwerwagn
Jan 16, 2008
601
217
Bosque Farms, NM
Lol funny you bring this up. I was just contemplating this today as well but more spec TT scale. I was kinda thinking even though 1st might be useless, and the weight detrimental, an nv5600 could potentially hold up? Shifting would likely be sucky tho with anything remotely close to a short throw...
I think a manual ecotec would be fun in a little truck.
racer56
Sep 10, 2007
2,288
483
Encino, Ca
If it you are going to race it will not last, but if you are going to play you might have a chance. It has been tried recently by multiple people and has not lasted.
shifter
Feb 23, 2010
188
12
costa mesa,ca
This is a 4 or 5-speed, Straight cut gear, Dog box with a built in quickchange. The box can be run as a H-pattern, Sequential or a Semi-automatic. We have adapted it to run as a 4wd, Millen,Greaves,Huseman,Barron. It uses a Torque converter or a clutch. There are 39 different gear ratios and just as many quick change ratios. None of the forward gears are direct drive so you can run a strong ring and pinion and get the ratio you need throught the combination of the forward gears and the quickchange.
pat W
standfast
Jul 16, 2007
334
113
Abq, NM
What about if the weight was cut way down to around 2800 race ready and was on 33 inch tires. Strong enough for that?
Shifter, that sure is a nice box there. I will call to get the skinny on it.
racer56
Sep 10, 2007
2,288
483
Encino, Ca
The two vehicle's that have tried it were both 2,800 lbs or less and with 33" tires. In the long run they will not take the punishment desert racing requires.
standfast
Jul 16, 2007
334
113
Abq, NM
Good to know. I am curious if a built up to would be up to the task. What transmissions did you try?
