AssBurns
- 14
- 3
I'm looking for some opinions and some tech info on the Ford Bronco Dana 44 TTB suspension. A quick idea of what I'm looking to do. I have a 3rd gen 4Runner that I am considering doing a TTB swap in. I want to build a dual purpose vehicle that can take the desert at higher speeds while still being able to do some mild crawling/ technical stuff. Not trying to build something to take to the Hammers but something that can still handle some mild crawling. The goal would to keep a semi-low COG while keeping some good up travel (around 8" or so). I know that these front ends are capable of pulling 16' of clean, usable travel so that 16' number is what i'm shooting for. I have a few questions and would like to ask for some measurements from a bronco to get a better idea of things. I have some ideas in my head and I don't have a Bronco to take measurements on right now.
First, what exactly limits a Bronco on the up travel besides fender clearance? I can make room for tires. I'm assuming the frame is the first thing to limit up travel? How much lift on a Bronco is needed to get roughly 8" of up travel?
I see that most of the LT guys like to do a Cut and Turn on the beams instead of Drop Brackets. The cut and turn sounds like it causes more stress on the u-joints. In crawling situations, additional U-joint stress is not good. The drop brackets cause more stress on the frame, but what if I build the crossmember and beam mounts to have about 2" drop from what a stock Bronco has. This should be plenty strong and not much extra stress on the frame. If I need to correct the camber for a higher ride height, I could always do the cut and turn at the LBJ. How much do stock beam mounts hang below the bronco frame rails?
One of the reasons I'm thinking of going for more of a drop bracket style is because I hear that when you have your beam pivots mounted up higher, you get jacking on off camber/ side-hilling situations. I'm sure there are other reasons to go one way or the other, so I'd like to hear your opinions on this. How does the handling and cornering get effected between a drop bracket style and cut n turn style lift?
