Tubing Notchers...
sirhk100
Aug 27, 2001
2,797
678
las vegas, Nv
What's the price range on a decent vice mounted notcher for home garge use? Nothing industrial... I'm assuming hole saw, drill powered style. Brands recommended? Where to get them? Any to avoid? Trying to get all the tools aquired so when I get the new ride I can actually get started on screwing it all up myself!!!! :)
'92 Ford Exploder (AKA Dezert Limo cause it's loaded)
1992f150
Dec 23, 2001
373
Azusa, Shame of the foothills
www.y2khai.com
JD, and protools should carry good notchers (150-200 bucks or so). I have a 30 dollar harbor freight notcher, I end up using a grinder insted most of the time. It doesnt notch quite on center, high about 1/16 to 1/8th of an inch. If you need to notch a short piece, or put a notch right next to a bend, the tube wont clamp up right and you can't notch it. On the short pieces, you can add on some extra tube and tack weld it, then it will clamp. The other problem is it will only notch to 45 degrees, most of the time I need an angle greater than this.
Oh one thing some (most?) notchers use a 1/2" shaft, so make sure the drill you want to use has a 1/2" chuck and not 3/8ths. Otherwise you can convert it with a new chuck for like 15 bucks.
http://www.off-road.com/chevy/jointjigger/notcher.html
Azusa: shame of the foothills
singlehanded
Jun 3, 2001
1,584
Placentia,Orange County
Ive got a dezert tools ones was around 300 bucks.
cleartoy
Aug 20, 2001
956
Oceanside,CA
Got my JD2 at Baja and LOVE IT.
94 Toyota stdcab 2x4
99 Yamaha YZ250
Got Sand??
tre5
Apr 3, 2003
829
18
Goodyear,AZ (east LA)
williams lowbuck tools sells a notcher for 300 bucks. the nice thing is its not a drill press deal. It is more like a shear, in that it has different size dies and you just stick the end of the tube in and pull down. One side at a time, but is still alot faster then a drill press. The only bad thing about it is that it is only good for close to 90 degrees.
Tre5
bpthirteen
Nov 17, 2001
712
42
San Clemente, CA.
www.bajahq.com
sirhk100
Aug 27, 2001
2,797
678
las vegas, Nv
Yeah, at work we have three different methods of notching. We use an abrasive setup like the pictures. We also have a punch setup probably similar to the one talked about above that we do our stainless on, except it's on a punch, not pulling a lever. Then I also setup our CNC mill to do some of our tubing depending on quantity and fixture availability...
1992f150
Dec 23, 2001
373
www.y2khai.com
yes they have some that are like a mill laid on its side....actually like a simple lathe, stick a mill flute bit into the chuck, then the tube gets clamped into where the tool post would go on a real lathe (compound slide?). You can set the degrees, and use 2 hand cranks to move the tube right and left, forward and back to make the notch. Alot cleaner, faster and quieter (and more expensive) than a hole saw type.
motoxscott
Feb 5, 2002
1,240
299
Huntington Beach, CA (SoCal)
So what do you think is the better setup, the abrasive or the lathe/mill setup ?
I've seen both but what are the pro's and con's to each ? Does one do something better than the other and vice versa ?
Both aren't cheap, thats for sure.
-Scott
1992f150
Dec 23, 2001
373
www.y2khai.com
Ive never used an abrasive one so I couldnt comment. The mill one is quiet though, no sparks, and you could do hundreds of notches on one cutting bit. You do need a different bit when you want to do a notch to fit up against a different size tube, so that would add to the cost. Im assuming the abrasive one you could just adjust it without buying anything, but maybe not.
