Updated pics of our project ranger
Brice
489
34
Brice
489
34
its ranger glass, 10" wider on each side
its overall 6'' wider per side. 19" of travel. w/ limiting straps prolly 18. Hopefully it wont look rediculous because the glass is gonna cover up the tires.
Brice
489
34
'nother pic at full compression
SpareChangeRacng
606
Yeah what year cab style do the fenders fit, and what year grille, etc are you running? I am planning on making some fenders that wide because I couldn't find anybody that makes some. I've been so busy though I've only been able to gather some of the supplies. If the ones you have will fit my truck (89 cab running 98 front end) I might be interested in a set. Steve
Just4Fun
83
Just wondering why you didn't build a double sheer upright and junk the spindle?
Jason
P.M. Fabrication
Brice
489
34
ya we are kicking oursaelves now for not doing it. def would have been owrth the work. o well when the spindle breaks we'll just have to make a whole new front end. centermounted a arms, 25'' of travel
Brice
489
34
the glass is made by [erry mcniels nephew. he has afab shop by off the hook(jesus i've seen some S-H-I-T-T-Y stuff come outta there
). we will be using the stock grill and widening a stock bumper to fit the fenders. should look badass.
SpareChangeRacng
606
Is it Chad McNeil then (I know he has a shop right next to Perry's), and can I have the contact info please? Steve
shrek
1,342
60
Why did you not flange and bolt the shock tower support?? Never plan on doing an engine?? knock on wood.......
Shrek
Brice
489
34
decided to be lazy and wait til we need to do something internally to cuz and flange the engine cage.
Brice
489
34
trailing arms
close up of shock mounts
front mounts
In_the_works
305
I may not know what I'm talking about, but the lower shock and C/O bolt holes on your lower links look like they're a little too close to the end of the plate (i.e. not much material strength). Am I wrong?
as long as limit straps are used in a different location it is OK.
michael_loomis
26,214
2,426
i dont know ... i agree with in the works especially if there over the center line as they appear to be .
SLR
252
69
I just finish fixing a set of lower links with a similar design. Your Material looks a little thin around the shock radius, I would recommend adding a gusset similar to my attached photo. Add some material and run it>>>>>SLR
SLR
252
69
BROKEN ATTACHMENT
Brice
489
34
thanks for the replys. ya we will be welding sleeves onto those holest. the plate is doubled up. its actually pretty thick, its just decieving in the pic. we will also be webbng the ends of the mounts.
