kramnamhoh
- 8
- 1
Hi All !!
My relatively new-to-me prerunner has a problem with the front wheel camber. The adjustment available is far from being adequate for setting the camber. It's as if the upper A-arm frame mounts are not far enough from the vehicle centerline to adequately set the camber. From my crude measurements, the passenger side mount is about 1 inch too close to midline , and the driver side is about 2 inches too close to midline.
Geiser Brothers suggested extending the A arm length. That seems to be the more expensive, though possibly correct option.
Has anyone had experience with a similar issue? Is extending the upper A arm length the best way to solve this issue?
thanks!!
thanks!!
