V8 guys, what gears with 33-35" tires
COChev
May 6, 2002
Bend, OR
V8 guys, what gears with 33-35\" tires
whatcha runnin in this tire range? 3.73-4.10 is my guess 4.56 might be too steep. not racing, just fire roads and sand dunes.
Chris_Wilson
Apr 4, 2001
3,323
1,403
Re: V8 guys, what gears with 33-35\" tires
4.11 with a 3 speed auto, 4.56 with an overdrive auto for 33-35's and a decent running sm block.
FABRICATOR
Apr 3, 2001
5,146
108
Ventura County, CA
Re: V8 guys, what gears with 33-35" tires
Overdrive is a major factor along with truck weight. A 454 will pull well street or dirt with 33"- OD - 3.73s. Anything less than a big block or a 383 stroker small block would not like 373 w/OD and big tires. A good running small block with 4.10 is a nice combination. BTW, overdrives are not all the same; 700R4 OD is .70 to 1, 4L80E .75 , E40D .71, 518 & 618/47RH (Dodge) .69.
Eric_M
Sep 27, 2002
189
Montrose, Co.
little bit off topic, but maybe fabricator would know. i have a 4 speed stick in my 89 4 banger yota. and was wondering, what the gear ratios are for the 4 speed? and i do plan on swaping the 4 speed for a 5 speed sometime in the future! so if anyone wants to trade and has a good 5 speed, i might be interested, but dont have much money, gotta save up for my tc uniball kit!
stupid people shouldnt breed!
Ryno
Sep 24, 2001
1,230
33
Yucaipa, CA
If your running a turbo400, 4.10's will do fine. I have 33" tires on my chevy with 3.73's, and it does fine, the top end is really nice. My friends with 35's and lifts all have 4.56's. I think 4.10's would do okay, but you'd only want to put it into OD when your on the highway. The chevy 4l60e/ 700R4 don't do well with the heat from larger tires.
Ryno
SANDlessNSeattle
rock solid user name
Dec 14, 2002
436
11
Brier, Wa. USA
Just my uneducated opinion......33''s go 4:10 / 4:56... 35''s goto 4:86-5:13 I had the 56's in a f150 with a stock 302 (95) and only needed to click the OD on over 85 on the hiway.......
Start drinking till you see double and act single
FABRICATOR
Apr 3, 2001
5,146
108
Ventura County, CA
I'm not sure what transmission you have in your truck. What I don't know about Toyotas would fill a big book about Toyotas. If the 4 speed is an H42 it has a 3.55 1st, 2.29 2nd, 1.41 3rd, 1.0 4th, and 4.72 reverse. If the 5 speed is the H55F it has a 4.84 1st, 2.61 2nd, 1.51 3rd, 1.0 4th, .84 5th (OD), and 4.84 reverse. There are other transmissions, so to be sure you need to identify which one you have.
