VW Clutch problem
JOSH
245
Here is the deal, 1835CC VW in a two seat high jumper chassis with a Rancho Pro Sand Box
The clutch will not disengage, we just put in a new slave and that didn’t do it. Took the clutch out, all looks fine, no abnormal wear, plates still have life on them. Anyone have any ideas? Just curious, I don’t have a problem with buying a new clutch, just want to know why it’s not working.
Thanks
Josh
1992f150
373
did you make any changes before it stopped working, or did it just break while you were offroading?
michael_loomis
26,214
2,425
is there pressure going to the slave ? is it working correctly ? lol ive seen them in backwards , and they dont work so well
is it entirely bled .. if it has air in it , it may work when disconnected , but not under load.
AllwaysRcn
1,004
20
Might have the wrong throwout bearing assy. May need a different style which requires you to remove the center piece of the pressure plate (for clearance).
JOSH
245
They funny thing is everything worked fine when i took it apart, I had to replace the trans, didnt touch the clutch, unless rancho gave me the wrong throw-out back, but it fits in just like it should.
AllwaysRcn
1,004
20
that's exactly what happened to me. new transmission w/new case=different throwout configuration.
Wayne_Nosala
2,216
133
Is it swing axle or IRS?
Some throw out setups require a "ring" on the pressure plate. some
some have a guide ring on the bell housing side, one is not compatible with the
other, maybe a picture posted of the
pressure plate & bell housing would be the easiest way to solve the problem here.
BitorPerformance
69
All you need to do is check the throwout bearing shaft if you need to use the bearing with the attached clips then no spacer on the pressure plate is requiered, but if the bearing uses the clips that are not attached to the bearing u do need a spacer
