Water Wetter
ATS 89 Yota
Jan 16, 2006
72
20
So. Cal
Worth the money? All hype or does it actually work?
Feb 19, 2002
6,850
1,685
Easton, KS
Every motor I have taken apart where it was used was full of chalky white crap in the water passages. Would not recommend.
07FJRog
Feb 26, 2009
3,325
372
Tonopah, AZ
I ran it for several years in my Northstar powered sandcar, never any issues or discoloration. I also used it with Gm recommended coolant, ( about half of normal qty)
BTW, it will run cooler with just water and water wetter, No antifeeze.
I prefer Engine Ice, but it get pricey for a larger motor
Tipracer
Sep 6, 2005
3,566
334
So. CA
I was under the impression that the only reason to use this stuff was on drag cars where they were not allowed to use antifreeze.
Tipracer
Sep 6, 2005
3,566
334
So. CA
wonder if that was because they didnt use distilled water...chaulky reside=hard water?
racer56
Sep 10, 2007
2,288
483
Encino, Ca
I have run water mixed with water wetter for 10 + years and could not be happier. Engines definitely run cooler with just water and water wetter added. The purpose of running water wetter is to prevent internal corrosion from just straight water, no anti freeze.
07FJRog
Feb 26, 2009
3,325
372
Tonopah, AZ
Yup,
it does more too , it reduces the vapor bubbles in the water jackets to ensure the maximum water molocules run along the surfaces and draw heat away.
jrtorres
Feb 12, 2008
853
48
Oak Hills CA
yep it works....and the white residue mentioned above is from another sourse. we usually run 20 degrees cooler using it
mebuildit
Sep 1, 2006
236
16
Scottsdale, Arizona
We run Napa Cool (Napa Auto) in our cars. Seems to work better that Water Wetter does comparing the two.
Might give it a try for your application.
Dezertpilot
Jul 26, 2005
5,716
527
Yuma, Az
I heard that the water wetter like the Redline all it does is reduce the friction of the water at the radiator. I dont know how true this is but I have run it in the past and didnt notice a difference.
GHARACING
Jun 26, 2006
1,043
240
Palm Desert
every time we prep or drain the radiator we always add a bottle. seems to run a tad bit cooler. our motor always runs cool though.
scottm
Feb 7, 2005
1,907
603
scottsdale AZ
www.cemaz.com
It exists mainly because race cars of all kinds are not allowed to run coolant. It provides corrosion protection, lubrication for the water pump seal, and a detergent to reduce water surface tension, which reduces trapped bubbles and improves thermal transfer. As everyone else said, with good water it does work, and it will help when using coolant too. Only downside is it has no freezing protection, so it is only for warm conditions.
Sparky
Apr 4, 2006
704
39
Feeniks, Aridzona
Just run a propylene based coolant. Sierra is one of the brands at auto parts stores. It has better heat transfer qualities than ethylene based coolant. Sure you can use Engine Ice (which is propylene based) if you like spending 4x more than you need to. Run it at about 40% coolant and 60% distilled water.
jrtorres
Feb 12, 2008
853
48
Oak Hills CA
Another option is Justice Brothers.....we have switched to that recently and in 7 different cars! all perform just as well as the water wetter which is much more expensive. As a side note (sorry to hi-jack) We have switched alot of things around the shop to justice brothers...they even have a "wd-40" type oil that works better than wd..and all of it is loads less money for just as good performance IMO..
