Weird Project Need some geometry numbers or advice
Jamespatrickdj
Jun 8, 2018
British Columbia
Im brewing up a project and am looking for some numbers or some cad files to help with it.
I want to take a Subaru WRX and fabrication a long travel suspension for it and give it some extra ground clearance obviously
ill replace the strut suspension up front with double a arm.
also track width isn't something im concerned with I fully expect this to get much wider than stock
My question is can I just take the dimensions of all the moving parts and make the XX% longer?
Is there a formula for long/short arm suspensions that I can follow and adjust accordingly to the specific. vehicle?
if there are other threads that answer this a link would be appreciated ( I promise I looked)
Feb 19, 2002
6,765
1,604
Easton, KS
Basics
Figure out what hubs you are running, choose rims that will give you minimal scrub radius with your desired tires.
Stretech lowers to get desired track width/travel.
Figure out upper arm length and pivot height to get desired camber curve.
Figure out shock mounts.
Figure out axles.
