SteelShield
- 36
- 11
Rust got you down? Tired of scouring away all that corrosion each time you want to lay down some welds? Try Mavcoat Steel Shield for a great layer of protection against the elements while your pipes, sheets, or tabs sit and wait to be used again.
Mavcoat Steel Shield is a corrosion prevention coating that prevents rust from forming on all metal components. Steel Shield is 100% weldable, meaning you don't have to remove it before welding. Mavcoat Steel Shield also dries to the touch, dries clear, and provides protection against all types of corrosion and oxidation for anywhere from 6-12 months. This product is perfect for all builder, welders, and fabricators too!
www.mavcoatsteelshield.com
