welding brass
jason@gmachine
Dec 7, 2006
376
12
signal hill CA
I need to patch some old pieces for a very old BBQ. They are Brass and I have a few questions.
1. What is the best way to weld to brass, TIG?
2. What is the recommended gas and rod?
thanks
jason
tmathews
Feb 2, 2005
1,060
30
Alpine, Ca
I have seen some people use silicon bronze... Tig welded.. You could try using a low temp solder kit with an acetylene torch.
atomicjoe23
Feb 2, 2008
4,058
73
Silverdale, WA
Try brazing. . .
. . .which part of the grill, will it see excessive temp's. . .although if the brass isn't melting then your braze shouldn't either.
Can't tell you what brazing rod off the top of my head. . .but oxy-acetylene, propylene, oxy-propane, any of those that are hot enough to melt the brazing rod would be fine since you aren't melting the parent material.
I would suggest braze welding before soldering. . .but if you do solder make sure you don't use lead solder, but food grade solder instead.
RyanWiW
Nov 27, 2007
143
9
torrance, ca
www.wilmingtonironworks.com
Jason, welding brass is very tricky. I would recoomend silicon bronze rod (it's actually a braizng rod) with your welder on DC and argon for shielding. Be careful, silicon bronze fumes are not good for you, so be in a well ventilated area or wear a respirator. It's a braze so don't melt the base metal to much. If this doesnt work out well for you, try silver solder with a OA torch.
DBMETALWORX
Jul 11, 2007
1,552
47
BUCKEYE AZ
WWW.DBMETALWORX.COM
although i used no filler, i tig welded a brass fitting on my old steam cleaner with ac current... it held 2500 psi for years... is this part cast?
racer56
Sep 10, 2007
2,288
483
Encino, Ca
thanks
jason
Go see Andy Bondio @ Bondio Fab in Torrance. He can fix that for you.
atomicjoe23
Feb 2, 2008
4,058
73
Silverdale, WA
Give it a try. . .if you already have a TIG welder. . .use the silicon bronze filler rod and give it a try. . .
. . .my instructor used to do this to me at the end of my time in weld school. . .he would give me one of the junior students projects from at home that needed fixed and I just had to figure it out. The hardest was a "stainless steel" cooking pot that the spot welds on the handle had given out on. . .turns out it wasn't a "stainless steel" pot. . .it was a clad pot that melted like no body's business. . .it wasn't very pretty initially, but once I finally shoved enough filler metal into the puddle to keep it from blowing a hole in the pot I was able to get an pneumatic grinder with a scotch brite pad on it and grind/polish it down nice and smooth!
mcidge
Jan 25, 2009
93
Canmore, Alberta
Try using silver solder with a borax flux. We use this in refrigeration all the time when joining dissimilar metals and it produces a very strong joint. Just watch your heat, don't get it too hot. You will notice the water boil out of the flux and soon after that your ready to add silver. Once you think you have enough silver back off on your heat a bit and chase the shiny spot on the outside of whatever you joined. Your done. Just don't get it too hot.
Chase 2
Jan 8, 2005
3,428
276
Simi Valley, CA
I see that you are in Signal Hill. If you are going to take it somewhere to be done, I suggest you call Roger Sanderson at Pipeworks Fab in Long Beach. He's @ 1471 Cota St. (Between PCH & Anaheim just west of Santa Fe). 562 432 6826. Roger does a lot of marine work with bronze and brass along with stainless & aluminum.
DUMP!
Jan 22, 2005
758
105
Anaheim, California
I'm sure that's just what Andy wants to be working on. :D:D
Please let me know if he fixes this so I can rev him up about working on a BBQ.
He looks down his nose at off roaders, What do you think he'll say about a BBQ?? :D:D:D:D:D
Dump
racer56
Sep 10, 2007
2,288
483
Encino, Ca
Dump
It all depends on who asks. When andy knows its for you he just says no.:rolleyes:
Brian Mapes
Dec 13, 2002
812
14
Corona, Ca.
I have welded quite a bit of brass, Using the TIG process on AC with silicon bronze rod. The welds were on high pressure manifolds and they worked perfect. The welding is a bit tricky because of all the zinc in the base metal. Here are a couple pics or the brass manifolds I welded.
Brian Mapes
Dec 13, 2002
812
14
Corona, Ca.
Well for that particular application the machine I had at the time was not powerful enough to get a puddle going so I needed to preheat. But also since these were high pressure manifolds I believe that is is better to have the whole part heated evenly so it is all the same strength. Preheating also helps pull some of the zinc out and to the surface i personally believe, the zinc is you main enemy when welding brass because it pops and creates porus welds so you sometimes have to weld grind and then weld again. The first weld gets rid of the zinc and then the second time there is less zinc and you can make a better weld.
maxyedor
Mar 11, 2007
397
22
Thousand Oaks
What kind of frequency, balance and amps are you running on brass? Tried welding it a couple times, but on DC which could explain my total failure to accomplish anything, not sure exactly why I would ever need to weld brass, but it sounds useful.
Kbach66
May 9, 2002
605
14
Simi Valley, CA
Dump
I'll have to ask him if he's going to have a BBQ at the shop anytime soon. We can eat at the shop instead of going out to lunch when we go over there!!!
