atomicjoe23
- 4,058
- 72
I'm not really sure if this belongs in this forum section or not. . .it was either here or suspension steering and here seemed a little more fitting. . .if it doesn't belong here, my apologies and hopefully the moderator will move it. . .
. . .back to the question at hand. . .I'm thinking of building a set of my own uprights for a budget play buggy based on Class 10 rules and using a 2.0" snout. . .
so. . .what, if any, OEM hub/rotor/caliper combination could I use with a 2.0" snout? This is my first forray into doing something completely custom, in the past it has just been upgrading OEM parts with a better, application specific aftermarket part, so I apologize for my ignorance ahead of time. . .I know that I can get aftermarket parts specifically for the 2.0" snout, but they are kinda pricy and I'm a college student so I was hoping to start out with OEM parts that I scavenge from the junkyard. . .that way at least I can build the buggy initially at a reasonable price and in a reasonable amount of time and start enjoying, then as I can afford to, or as I need to because I break stuff I can upgrade to racing parts. . .
. . .I will be building the chassis to full Class 10 specs and then upgrading the running gear as I can afford it.
Thanks!
Thanks!
