whats the problem?
singlehanded
Jun 3, 2001
1,584
Placentia,Orange County
Ok got my c4 in my ranger all hooked up except adjusting the shifter cable and it wont start. I have figured out that the starter gear is about half an inch to short to turn the flexplate. Do I need a new starter or a flex[plate or ? The guy I bought it from said it would bolt right up and he had it bolted to a 4 litre ranger extra cab. ANY IDEA'S---- I think I gonna call the guy I bought it from since he is not returned my last 2 e-mails.
Jun 18, 2001
299
SOunds like you got the shaft from that guy. Check your PM.
singlehanded
Jun 3, 2001
1,584
Talk to the guy tonight and he was very helpful. He had it in an 90 auto,and mine is a94 stick. He said that maybe the starters are different lengths auto and stick anyone know offhand.
thanks
singlehanded
Jun 3, 2001
1,584
got the auto starter this morning and going to install this afternoon or friday. then I will letyou guys know if it is running.
by the way the auto looks a bout a 1/2 longer so it should work.
singlehanded
Jun 3, 2001
1,584
Its a running, only a few things left to do before I am driving it. Anyone got any pictures of how to hook up the shifter linkage to the trans the part that holds the outerpeice so only the inner cable works on a c4 or similar?Or some good advise havent done this before.
hoeker
Oct 9, 2002
2,004
101
holland, MI
www.rosshoek.com
usually the bracket that comes with the shifter just bolts to 2 of the pan bolts. make sure you get that linkage adjusted right!
