Who does a engine and trans swap?
Honda48X
1,150
1,412
I have a pre-runner that currently has a bus trans and a 2180 VW engine. Not enough power and need to take it in and have it replaced with a bigger engine. Any advice on a location near Yuma or El Centro ca. Here are some pics of the engine area. It currently has 930cvs. New to the Pre-runner world.
Honda48X
1,150
1,412
Thank you. Any thoughts on what I should put in? I’ve been told a Ecotec or would a another type of motor work. Trying to keep my costs down so I can’t put a LS in there. Someone was saying a Subaru engine.
16,402
3,523
Both are viable choices. I've also heard that the Honda Fit engine is a compact, reliable package, but I'm not sure adapters are available for it.
Good luck with your plans.
Honda48X
1,150
1,412
Thank you Garrett. I think for the space I will need a compact motor.
burninfuel
716
166
you might be running the wrong transaxle, type 2 or better 091.
they have a 538 ring and and with close ratio 3-4th gearset you could still do 80 mph.
close ratio "sand trans" are available.
Benco bus box
