winters shifter for a bronco with the E40D trans
has anybody installed a winters shifter on a E40D trans? my question is how does the overdrive work with this shifter? also i heard theres a part you have to change on the transmission itself..anybody?, thx.....
F1shifty
i just did it on my aode. Im sure it cant be too different. The part you have to change is the shift shaft where the linkage hooks up. Not a big deal. As far as the O/D. If your referring to turning it off, i plan to run the switch down to the shifter somewhere. That light is important too being it flashes the codes if something goes wrong. Good luck
