Winters shifter
Dirtracer 619
Nov 28, 2007
1,066
128
Ramona Ca
Have a C4 and winters shifter
60” cable
To get the cable to line up using the cable mounts. There is only like two threads on each end going into the cable block and the shift adapter
What am o doing wrong
BTFfabrication
Mar 5, 2019
101
135
Upland
Maybe the shift arm on the trans can be flipped around? 2” or 3” throw on the cable? Just throwing out random questions.
RaceTec Pistons
Feb 3, 2009
38
13
Huntington Beach, California
www.RaceTecPistons.com
Check where the cable clamps are for the fixed position on both the shifter and the trans pan bracket. Also make sure your trans pan bracket is on the correct set of holes. The easiest way is to loosen everything up and adjust it all that way then tighten everything down once the detents on the transmission match the gate. Also make sure that the block in the shifter is in the correct hole in the bottom plates. Too many years at the old Art Carr building these damn things!
Dirtracer 619
Nov 28, 2007
1,066
128
Ramona Ca
We're going to try and build a longer cable block that sits in the shifter hopefully that will work also will check for correct hole.
