Baja Designs says ( 130 ) watt output necessary.....does XR650L put out 130 watts or will i need to upgrade stator also ? Thanks.
With your stock stator generating 150watts you will be able to power two 55watt Halogen lights or two HID lights. One light will be powered via the running light and the other light will come on in the high beam position.
Diego, say "Troy just hole shoted me"![]()
Thanks, I like the dual 4'' setup but I need to use with the factory headlight since I will be riding on highway, it is much harder to mount these in order to keep factory light ?
