XX tech and parts thread
43mod
3,418
2,756
I like hyshok redline but no cx experience w it, yet.
i had benchmark performance go though my 20 trans. They found one bearing
Minus a needle ! B ew trans. 20 gears were wider
43mod
3,418
2,756
Anyone know the xx factory engine warranty off the top of tgeir head ? I think i have an issue w pre runner xx piston/ plug. Thought i might take it in to my dealer that kinda sucks
43mod
3,418
2,756
Has anyone found a boot for rack and pinion to speed tie rod other than stretching the factory boot to fit the larger tie rod ? Much progress today thanks to Osborne coming down and forcing me to work on race rig,thanks.
43mod
3,418
2,756
Finally going to figure out why my pre runner xx wont run. Plugs good. Found intake tubes pulled away from head. Engine mounting afu ! Decided tractors were more fun for the afternoon. Woll tear it down tomorrow. Meed it to bevready to pre run the 500. Wish i would have put that extra mount in before breaking things........
7,261
3,932
pictures ,or its fake news...🤣
43mod
3,418
2,756
They were intact. Engine should come out tonight for inspection and repair. 775fab mounts going in along w jagged s high capacity dry sump tank and speed h2o pump kit. It should never break again right ? 😂
afortune46
91
158
well not until the next time... lol
43mod
3,418
2,756
Looking fir a simple clutch blower install i came up w this. It flows into both intake tubes. Hope it works. Probably the easiest mod i have made.
43mod
3,418
2,756
Already done. Still not enough. I am more a fab guy than tuner. I need you to make my clutch work better !
novaman64
267
142
Hah, ive been playing with different springs and weights.. I think I finally got mine dialed… What size tires are you running?
7,261
3,932
what gets hot& what fails? belt i assume, ?, part getting hot that causes failure needs more heatsink, some kinda finned/ slabb of aluminum attached somehow to 'hot 'part to ' soke' up excesses heat& disspearse it through the air from fans more efficiently
afortune46
91
158
Make sure you aren't preventing air flow in bound by obstructing the intake like that , our short course cars use an additional intake so we increase the cfm going into that compartment , we also vent the back side of the cover to increase outlet pressure.
slvrbullet
177
73
Alex, do you have any pictures of the setups you guys have on the Speedwerx cars.
43mod
3,418
2,756
The air box is already divided between ckutch and engine sides so i think i am ok. We shall see if it helps or not. So far no need for more power if belts are too hot. I finally bought good belts instead of being cheap about it. Heading to the 500 right now.
afortune46
91
158
I'll get you some pictures this weekend when I get to Crandon , if I have service ill post up but I'm not holding my breath on having anything for cell coverage.
Its more for the correct scfm , at idle your bilge pump will produce more than the clutch fan can but at higher rpm the clutch fan will want to pull more air than what the bilge pump can provide and it chokes down the inlet process, the outlet is ok in stock form but the pressure from an additional inlet can benefit with an additional outlet.
Another thing we learned is break in your belts all in advance - we run oem belts and put 100 miles on them before they ever get put on a racecar on the track , varying throttle speed limiting any wot pulls and making sure the exposed edges are all good and heat cycled. When you're on the line or getting ready to go out its always good to keep the belt good and hot especially running oversized/heavy tires, cycling the rpm's in neutral will get and keep the belt warm, that way when its go time and you push on the loud peddle the belt is hot , gripping and you dont slip it and hour glass it.
7,261
3,932
curious , do belts go through ' heat cycles' like race tires?, after a few the rubber gets too hard, and tires just dont get stickey, they dont wear, but they just slide all over and get Hot, are there different ' race compounds' in belts like in race tires?,
afortune46
91
158
They do , but it takes a very long time and its all dependent on conditions - if you stay up on your clutch maintenance (blowing clutches out every so often etc) you'll see rubber building up on it.
for example - in the AC 800 snowmobile there are two belts for it suffix 083 and 084 , the 083 is a std rubber belt , it provides excellent grip but its dimensions vary as it heats up. The 084 is similar to the XX belt as its kevlar re-enforced - it takes time to heat it up but once its hot it will grip like the 083 and it holds it dimensions much tigher since thermal expansion of the belt is less. The problem is folks will run the 084 then throw 160+ hp into it and hour glass it because of wot conditions before its warm - this hour glasses the belt which leads to pulled cords and failures.
