yellow top - red top
charlie_brown
1,214
67
i have 2 red tops now on my truck hooked up through a rely. one of the red tops keeps acting up. it will work fine and in just an instant, it will be dead. i want to replace it with a yellow top. can i run one yellow top and one red top?
07FJRog
3,325
372
yes, the yellow is a dual cycle battery, made for heavy cycling and Cranking power.
red is just a starting batt, but they are compatible.
some of my friends run two yellows in thier diesel trucks, because thay have high power stereos
Rog
charlie_brown
1,214
67
o.k. so i can run a yellow top with my red top and not over load my alternator.
07FJRog
3,325
372
I just reread your orig post.
explain your relay setup and the purpose for it.
you will not over load your alt.
Rog
charlie_brown
1,214
67
i have 2 red tops going to a electric relay like a RV relay. then one wire out to my starter relay. one battery is for starting and some basic stock stuff. the other battery is powering up extra stuff.
i hooked up a switch to the relay so when my main battery is dead, i turn my key in the acc. position and push the button and it activates the relay to switch the batteries so i can start my truck.
it works pretty good but my main red top sucks and i have to switch it allot. that’s why i wanted to replace the one with a yellow top.
